Before Installation
Before installing your certificate, you will need to make sure you have downloaded the ZIP containing your certificate files. Haven't downloaded your ZIP-file yet? Follow these steps to download your certificate and get ready for installation on your web server.
Now chose your server type and follow the instructions there:
12 out of 85 found this helpful
