Installing SSL Certificate on Heroku
Below you will find instructions outlining how to install an SSL certificate on a Heroku web server. Please note that in order to install an SSL certificate on Heroku, you will need to purchase Heroku's SSL Endpoint Add-On.
Install Certificate:
As the first step, you will need to use the command line in order to create an SSL endpoint on Heroku. In your local environment, please execute the following command to create an SSL endpoint:
$ heroku addons:create ssl:endpoint
Next, you will need to upload your certificate.crt and ca_bundle.crt files into the SSL directory of your application. As soon as both files are uploaded, you will need to merge these files into one. To merge the files, run the following command:
$ cat example.crt ca_bundle.crt > certificate.crt
Now you can import your private.key file and your certificate.crt file using the command below:
$ heroku certs:add certificate.crt private.key
The response that follows will outline the details of your SSL certificate and installation, including the hostname selected for your SSL endpoint. Please note that in some cases it can take up to 30 minutes for your SSL endpoint to be created.
Adding SSL Endpoint to example… done
example now served by example-0000.herokussl.com.
Certificate details: [certificate details]
Expires at: [certificate details]
Issuer: [certificate details]
Starts at: [certificate details]
In case you have not added the domain to your app yet, you can now run the following command:
$ heroku domains:add www.example.com
As soon as your SSL endpoint has been created successfully, you will need to create a CNAME record in order to route all future requests for your domain to the new Heroku SSL endpoint's hostname. The CNAME should like like the example record below:
  • Record typeCNAME
  • Name@ or www
  • Point Toexample-0000.herokussl.com
Please Note
The CNAME record above contains example information. You will need to add your own Heroku endpoint hostname in order for the record to work correctly. If you do not want to set a CNAME record for your root domain (@ or www), you can also specify one for a sub-domain.
You have completed all required steps to install your SSL certificate. To check whether or not your certificate has been installed correctly, simply use the built-in ZeroSSL "Check Installation" tool or try accessing your domain using HTTPS, e.g. https://domain.com.
0 out of 1 found this helpful
