Installing SSL Certificate on Tomcat
You can find instructions for installing an SSL certificate on a Tomcat web server below.
Step 1: Convert Certificate Files
First and foremost, you will need to convert your certificate.crt and ca_bundle.crt files from PEM (.crt) to PKCS#7 (.p7b). This can be done easily by using the OpenSSL command below:
openssl crl2pkcs7 -nocrl -certfile certificate.crt -out certificate.p7b -certfile ca_bundle.crt
Step 2: Upload Certificate Files to Server
Upload your converted certificate files (certificate.p7b and ca_bundle.p7b) as well as your private.key file to your server in a directory of your choice.
Step 3: Run Install Command
Next, you will need to run the following command in order to install your certificate:
keytool -import -trustcacerts -alias server -file your_file_name.p7b -keystore your_domain_name.jks
If your installation was successful, you should receive the following message: "Certificate reply was installed in keystore.". If you are prompted to confirm whether or not this certificate should be trusted, enter "Y" or "Yes" in order to confirm.
Step 4: Configure SSL Connector
Next, you will need to configure an SSL connector on your server, which will allow the server to accept secure connections via HTTPS. Locate and open the .xml configuration file, which is typically stored in the conf folder of your server's home directory.
Enter the keystore filename and password, as seen in the example below:
<Connector port="443" maxHttpHeaderSize="8192" maxThreads="150"  minSpareThreads="25" maxSpareThreads="75"  enableLookups="false" disableUploadTimeout="true"  acceptCount="100" scheme="https" secure="true" SSLEnabled="true" clientAuth="false" sslProtocol="TLS" keyAlias="server"  keystoreFile="/home/user_name/your_domain_name.jks"  keystorePass="your_keystore_password" />
Step 5: Restart Tomcat Server
Finally, restart your Tomcat server in order for your changes to come into effect.
Congratulations, you have completed all required steps to install your SSL certificate. To check whether or not your certificate has been installed correctly, simply use the built-in ZeroSSL "Check Installation" tool or try accessing your domain using HTTPS, e.g. https://domain.com.
0 out of 3 found this helpful
