Installing SSL Certificate on BigCommerce
The instructions below will outline how to install an SSL certificate on a BigCommerce web server. Please note that you will need your BigCommerce account credentials in order to log in to your BigCommerce account. If you have multiple servers, you will need to complete the steps below for each of the servers you would like to install SSL certificates on.
Install Certificate:
  1. Log in to your BigCommerce account and select "Server Settings"
  2. Select "SSL Certificate", then click "Add a 3rd Party"
  3. Now enter (copy & paste) your certificate files into the respective fields.
  4. Finally, click on "Install".
Please Note
It may take up to 20 minutes for your SSL certificate to be fully installed on your BigCommerce site.
