Installing SSL Certificate on cPanel
Below you will find instructions outlining how to install an SSL certificate on a cPanel web server.
Install Certificate:
  1. First, please log in to your cPanel account. Typically, you can access your account by navigating to https://domain.com:2083.
  2. Next, scroll down to the "Security" page of the cPanel homepage and select "SSL/TLS" to access the SSL/TLS Manager, which allows you to manage the configuation of SSL & TLS certificates.
  3. Click "Manage SSL Sites".
  4. Use the "Domain" dropdown menu to select the domain you would like to install your SSL certificate for.
  5. Now enter (copy & paste) your certificate files (certificate.crt, ca_bundle.crt & private.key) into the respective fields.
  6. Finally, click on "Install Certificate".
You have completed all required steps to install your SSL certificate. To check whether or not your certificate has been installed correctly, simply use the built-in ZeroSSL "Check Installation" tool or try accessing your domain using HTTPS, e.g. https://domain.com.
  Didn't work?
Troubleshooting
📧 You may want to reach out to us in this case.
15 out of 36 found this helpful
