Can I upgrade, downgrade and cancel anytime?
Yes, your subscription plan can be upgraded, downgraded or canceled at any time. Upgrades are effective immediately and downgrades come into effect at the end of the current billing period.
If you want to view your subscription click on the Account icon on the top right corner of your screen and select Subscription:
You can review your Subscription and Manage your Billing details as seen below:
0 out of 2 found this helpful
