Can I cancel a certificate?
You can, but only when your certificate is in "Draft" or "Pending Validation" status.
To cancel a certificate, navigate to the certificates list and choose the "Cancel Certificate" from the right-hand options menu. Once clicked, you will need to confirm your cancellation once more before it comes into effect.
If your certificate is already in "Issued" status, it cannot be canceled and you would need to wait for it to expire.
1 out of 17 found this helpful
