How do I access my previously created certificates?
Important
Any certificates you've previously created will be accessible under the following page: https://www.sslforfree.co/login
Here are the steps you need to take to view previously created certificates
  1. Open https://www.sslforfree.co/login
    You will be prompted to enter a username and password.
    NOTE: This is not where you enter your old login details.
    Enter the following:
    Username: sslforfree
    Password: 123sslforfree123
  2. You will then be directed to the regular login page where you can enter your old login details
  3. After you log in, you will able to view your previously created certificates.
1 out of 2 found this helpful
