πŸ”Ž Useful diagnostics tools during verification
If you receive any error messages before verifying, please check the below tools for more information:
   Check for User-Agent filter
During HTTP verification the file needs to be readable for our automated ZeroSSL systems. Some webservers can prevent that and only allow human interaction with a web-browser.
βœ…
When you get 200 OK everthing is okay.
It looks like your server has some kind of filter/firewall enabled.
πŸ‘‰ Check if your website is reachable for ZeroSSL
  curl domain.com/.well-known/pki-validation/
  ABCDEFGHIJKLMNOPQRSTUVWXYZ123456.txt
   Check for HTTP redirects
During HTTP verification the file needs to be available via HTTP 200 code. Any kind redirect can influence the verification result.
βœ…
Any redirect with 3XX can prevent a verification of your certificate
πŸ‘‰ Check if your website is reachable via HTTP 200
  curl -vv domain.com/.well-known/pki-validation/
0 out of 1 found this helpful
