Installing SSL Certificate on Hostinger
You can find instructions for installing an SSL certificate on a Hostinger web server below.
  1. Hostinger requires to copy & paste the SSL certificate into their management interface.
    💡 Please have a notepad ready.
  2. Now please follow the instructions in the Hostinger knowledge base.
    👉 Please refer to Hostinger for the installation
  3. Check Installation
    You have completed all the required steps to install your SSL certificate. To check whether or not your certificate has been installed correctly, simply use the built-in ZeroSSL "Check Installation" tool or try accessing your domain using HTTPS, e.g. https://domain.com.
1 out of 2 found this helpful
