Installing SSL Certificate on Other Common Platforms
Here you can find a list of some less common platforms where you can install your SSL certificate.
Strato
πŸ‘‰ Bitte klicken Sie hier fΓΌr die Anleitung von Strato.
Bitte das eigenes Zertifikat hochladen und nicht ein neues kaufen, das haben Sie schon hier gemacht.
FREEHOSTING
Free
πŸ‘‰ On the free plan you need to install it yourself via cPanel.
Paid
βœ… You should get an automated SSL certificate from FREEHOSTING.
web.com / register.com
You cannot use an SSL certificate from ZeroSSL, they require to use their own.
Wordpress
WordPress.com
βœ… If you have a managed instance at wordpress.com they offer free SSL on their own.
WordPress.org
πŸ‘‰ In case you have a self-hosted instance you need a 3rd party add-on to install the SSL certificate.
This list was updated the last time in November 2020
0 out of 5 found this helpful
