You can find instructions for installing an SSL certificate on a GoDaddy web server below.
GoDaddy offers different kinds of web hosting, please find out which product you have.
If you don't know this, they offer instructions as well.Now please choose your server type at GoDaddy.
Web Hosting - Linux
Web Hosting - Windows
WordPress Hosting
If you have a managed WordPress solution from GoDaddy, you can't use a certificate from ZeroSSL. GoDaddy will automatically install one for you.
You have completed all required steps to install your SSL certificate. To check whether or not your certificate has been installed correctly, simply use the built-in ZeroSSL "Check Installation" tool or try accessing your domain using HTTPS, e.g. https://domain.com.
