You can find instructions for installing an SSL certificate on a BigCommerce web server below.
- Log in to your BigCommerce account and select "Server Settings"
- Select "SSL Certificate", then click "Add a 3rd Party"
- Now enter (copy & paste) your certificate files into the respective fields.
- Finally, click on "Install".
You have completed all required steps to install your SSL certificate. To check whether or not your certificate has been installed correctly, simply use the built-in ZeroSSL "Check Installation" tool or try accessing your domain using HTTPS, e.g. https://domain.com.
Tips
- If you have multiple servers, you will need to complete the steps below for each of the servers you would like to install SSL certificates on.
- It may take up to 20 minutes for your SSL certificate to be fully installed on your BigCommerce site.
