Here you can find a list of some less common platforms where you can install your SSL certificate.
OVH Web Hosting
Strato
π Bitte klicken Sie hier fΓΌr die Anleitung von Strato.
Bitte das eigenes Zertifikat hochladen und nicht ein neues kaufen, das haben Sie schon hier gemacht.
FREEHOSTING
- Free
- π On the free plan you need to install it yourself via cPanel.
- Paid
- β You should get an automated SSL certificate from FREEHOSTING.
web.com / register.com
You cannot use an SSL certificate from ZeroSSL, they require to use their own.
Wordpress
- WordPress.com
- β If you have a managed instance at wordpress.com they offer free SSL on their own.
- WordPress.org
- π In case you have a self-hosted instance you need a 3rd party add-on to install the SSL certificate.
This list was updated the last time in November 2020
π’ My server is still not on this list
