You can find instructions for installing an SSL certificate on a WHM web server below.
- First, please log in to WHM. The login URL is typically available under: https://domain.com/2087
- On the WHM Homepage, click the "SSL/TLS" button.
- On the SSL/TLS Manager page, click "Install an SSL Certificate on a Domain".
- In the "Domain" input, enter the domain name you would like to secure with your new SSL certificate.
- Copy & paste the content of your certificate files (certificate.crt, ca_bundle.crt & private.key) into the corresponding inputs.
- Finally, click on "Install" to complete the process.
You have completed all required steps to install your SSL certificate. To check whether or not your certificate has been installed correctly, simply use the built-in ZeroSSL "Check Installation" tool or try accessing your domain using HTTPS, e.g. https://domain.com.
