You can find instructions for installing an SSL certificate on a Tomcat web server below. These instructions work with Tomcat v8 and above.
For details on specific configuration options please refer to the official Tomcat documentation for SSL.
- Make sure that OpenSSL is installed on the target machine or container along with Java and Tomcat before continuing
- Place the three files mentioned above in a directory where Tomcat can read them and set the permissions. In the next steps we'll use the directory /certs - please change the path accordingly.
- Edit the "server.xml" file.
- Make sure that it contains a line like this:
<Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" /> -
Next adapt the existing SSL listener in the same server.xml file or add a new one - don't forget to change the path accordingly:
<Connector port="8443" protocol="org.apache.coyote.http11.Http11AprProtocol" maxThreads="150" SSLEnabled="true" > <UpgradeProtocol className="org.apache.coyote.http2.Http2Protocol" /> <SSLHostConfig> <Certificate certificateKeyFile="/cert/private.key" certificateFile="/cert/certificate.crt" certificateChainFile="/cert/ca_bundle.crt" type="RSA" /> </SSLHostConfig> </Connector> - If you want Tomcat to listen on another port than 8443 please change
port="8443"to a value that suits you - If you don't want to offer Http/2 you can omit the line
<UpgradeProtocol .../>
💡 Do you have Feedback to the instalation of your SSL certificate?
