Before installing your certificate, you will need to make sure you have downloaded the ZIP containing your certificate files. Haven't downloaded your ZIP-file yet? Follow these steps to download your certificate and get ready for installation on your web server.
Now chose your server type and follow the instructions there:
- Installing SSL Certificate on WHM
- Installing SSL Certificate on Ubuntu
- Installing SSL Certificate on Tomcat
- Installing SSL Certificate on Plesk 12
- Installing SSL Certificate on NGINX
- Installing SSL Certificate on Heroku
- Installing SSL Certificate on Google App Engine
- Installing SSL Certificate on cPanel
- Installing SSL Certificate on BigCommerce
- Installing SSL Certificate on Amazon Web Services (AWS)
- Installing SSL Certificate on Apache
- Installing SSL Certificate on Hostinger
- Installing SSL Certificate on GoDaddy
- Installing SSL Certificate on other common platforms.
- 000webhost
- OVH Web Hosting
- IONOS
- Namecheap
- Mediatemple
- Strato
- FREEHOSTING
- web.com / register.com
- wordpress.com / wordpress.org
- Register.it
- Awardspace
- Wix
- Freehostia
- Gearhost
- smarterasp.net
- DigitalOcean
Your self-hosted server or cloud hosting provider is not on this list?
This is a question we often heard during conversations with our clients in customer service, that's why we decided to offer you a much easier option to provide us with your precious insights and tips for the ZeroSSL platform.
We partnered up with the company userwell.com, which is offering an easy-to-use interface to collect your insights.
