Depending on if you are a Free or Paid user we have different ways of how the quota is calculated.
Below you can find a brief explanation of the most common cases:
👉Certificates in "draft" and "pending validation" status are counted against that quota
👉 Make sure not to create any duplicates as they count against your quota of 3
In the example shown, the user has 1 draft certificate, 1 issued and 1 expired certificate; in order to issue 1 more certificate, the user has to cancel the draft certificate. If you don't know how to cancel a certificate, please check our this article: Cancelling an SSL Certificate
👉 unlimited 90-Day Certificates
👉 5 x Annual Certificates
You can create 5 independent Annual certificates for different domains.
In the example above, the user created an Annual certificate with 3 domains which will consume the quota for 3 x Annual certificates for this user.
👉 unlimited 90-Day Certificates and wildcard certificates
👉 15 x Annual Certificates
👉 1 x Annual wildcard certificate
The quota for an Annual certificate is calculated the same way as for the Basic subscription. You can create 15 x independent Annual certificates for different domains or create one Annual certificate for one domain and renew it ten times. The rules for multi-domain certificates are the same and with a wildcard SSL certificate, you can secure unlimited subdomains using one certificate at a single level.
⚠️ Use your wildcard certificate wisely as you only have 1
👉 30 x Annual Certificates
👉 4 x Annual wildcard certificate
You can issue 30 Annual certificates independently or use the multi-domain feature as long as you don't exceed the 30 domains in total for the Business subscription. With this subscription plan you can create 4 wildcard certificates.
⚠ Important to notice
❗Regardless of the subscription plan you are using, revoking a certificate will not free up space in your quota. Learn more about certificate revocation here .
